just for clarification yer magneto part is a spinning magnet that produces a spark via a coil on engines with no battery. In a car, say, with a battery and associated electrical system, the ignition coil is energised  electrically; on yer mower there isn't always an electrical system to charge the coil so a magneto is used. It is much simpler and more robust so well suited.
The alternator is used - on larger mowers tractor mowers and cars to produce an a.c. current for lighting which is then whatsisnamed - rectified! that's the badger! - by the diodes to produce a d.c. current which charges the battery.
Just for completeness: a dynamo produces a d.c. output directly.
The magnets in the top of a mower are big and can also be used to find nuts and bolts dropped in long grass because after forty years you still think there's no need to put a sheet down when you do a field repair. Idiot!
