I need to hire a big stump grinder for a load of big stumps and after this morning a mwep that will get in tight spaces after turning up on a job today and the neighbour said he would sue if i went over in to his property to do a 25% reduction over the guy i was working fors roof!
have tried orange plant but they are to far and would charge more in haulage than for the hire ,any ideas?
Aren't neighbours d1cks? I hate neighbours, IMO they should have all been put down at birth.
I'd be inclined to tell him if he doesn't allow access into the tree the your client is quite within his rights to sue him for future damage to his property, caused by his tree.
got a similar problem to sort out on friday.
Hey Matty, if you can 'prove' that the tree work is necessary maintenance, your customer could get a court order for you allowing you access to the neighbour's land.
A mewp may be less hassle though!
guys a fu9kin nut job.......what really got me was i gave him a load ash and sycomore rings for free last friday to butter him up becouse i new what he was gona be a D!ck..........on the funny side he offered me a cup of tea after he said he would sue...i declined nicely and went on my way
You try your best and still get aggro,the tree is going to get done any way,so why can't he just give you a brake! :banghead:
Acacia tree surgery based in Waterbeach (just outside Cambridge)have a large stump grinder they have one of there team using it every day. if this is any good to you
01223 861698
RQG18 fits thru a 900mm gap.
RQG15 is the better option, but they have a set footprint or area the legs need
Bear in mind that because of their length they need quite a good area to turn in once they get thru the gap
