 Hi,    I damaged the fuel filler 'neck'  (where the filler cap screws into) and it now has a hairline crack which allows fuel to escape.  Is there any sealer or glue i can use to seal it up?  @spudulike
10 hours ago, Will Heal said:
I’ve mended fuel tanks with araldite before
Yes but try and use the original rather than the rapid version. Mix the components very well and warm it with a hair dryer as this makes it set stronger and quicker. It also makes it far more runny
9 hours ago, Martin Tree Care said:
Will do, sure he would like a challenge!!!
Nearly new when it was digested by a big bad timberwolf.
Crank, piston, flywheel all in 20mm bits!! Easy fix?
Lucky it didn't do more damage :trytofly: Karabiner looks like it will go again.
Edited by peatff
