  • Replies 211
Yes, fairly straightforward.
If you want a side tip, then if you can find a three way tipper with a front mount crane you just turn the whole thing round on its subframe.
👍👍 Was yours a flatbed to start with or a tipper? Do you have the tipping gear underneath of use the hiab to tip the body?
IT was a flat when I bought it, I bought a three way tipper body with the subframe and ram from a breaker, and built my chip box on that.
If I was going to do it again I'd build the whole subframe and body from scratch, decent three way tip bodies are like hens teeth.
Is it possible to move a hiab from the front of the lorry to the back?
Can find plenty of front mounted hiabs.
Cheers..Al.
There's a 55 plate three tipper with crane piped for grab on auto trader, also a seddon three way tipper for £4750, just cut the body down and get a crane fitted on the back.
👍👍 Thanks for the heads up.
These big trucks seem incredible value compared to 3.5 tonners.
Do you need to eat Yorkies and regularly murder prostitutes to buy one?
Wrong Mark, I have never eaten a Yorkie bar :)
Bob
