39 minutes ago, huskykev said:
Is that your own machine dan?
no, belongs to a guy called joe, not sure if he's on the forum or not, pulled the pic from a facebook post
All these things have been considered in the past. But from a manufacturing point of view, the cost/benefit/numbers ratio is considered and that kills many projects.
In the 80's, I asked JCB if they would consider getting their apprenticeship team to design and build a chipper for me (GreenMech didn't exist and TW were in their infancy possibly) as I wanted British built rather than all the imported stuff.
They hinted that they might accept the challenge but only if sales exceeded 3000 pa. Killed it!!! If a project is run by accountants then, more often than not, it goes nowhere.
What’s the price range between a cs100 and your cheapest tow behind Pete? Peruzzo have already proven there’s a demand, albeit small, for a tracked mini chipper so surely it’s a logical progression to put feed rollers on a “backyard” chipper?
On 26/07/2018 at 00:42, huskykev said:
width of feed hopper,
compared to the width of a timberwolf 150VTR with removable hopper off
from the blurb
'This machine is perfect for access on restricted access contracts and can even pass through a standard 700mm doorway. The features and benefits of the TW150 VTR include:
  • Variable width tracks for easy access through narrow openings (quick remove funnel, tracks move in to 700mm)
  • Reliable Kubota 4 cyl. Diesel engine'
Edited by tree-fancier123
1 hour ago, Husqvarna King said:
Thought this looked cool, never seen one before
just seen that too, looks a decent buy if want a machine that size
from the blurb
TW125 is 112cm wide, measured from outer edges of the stop bar, which kind of kills it as a genuinely narrow access machine.
The idea still has some merit for me though.
It could still be a cheap way to have a tracked hydraulic chipper.
Make hopper removable with a bit of head scratching.
