Hi folks,
Β
Was pollarding a horse chestnut and I just want to know if this tree has the common bleeding canker? The alarming amount of flaking bark and lack of conkers looked like the signs of it. It looks like it suffers from the mining moth due to the leaf spots. Sure does look poorly.
Β
Hope you can help.
Β
Thanks,
Dan.
Edited by Gardenscape
One of the first chestnuts I’ve seen with out it in a long while.... is now mutilated... if it didn’t have problems from being defoliated prematurely by leaf miner for years it sure has them now.
Around Manchester and Saddleworth I'm see it less frequently. Where it's present on older trees they appear to be coping and there's very little recent flux or staining.
Β
Leaf miner and Guidnardia on the other hand areΒ almost ever present
The tree had massively outgrown its space and the owner didn't really like the tree. It had previously had work in the past and had limbs with rot. To be honest, it's an ugly tree in my opinion. So what is causing the flaking bark across the whole tree? That isn't normal for a Horse Chestnut. There is red staining also.
From the photos it looks like it would have looked nice with just a 25 percent thin.
  • Β
Arbtalk.co.uk is a hub for the arboriculture industry in the UK. Β
If you're just starting out and you need business, equipment, tech or training support you're in the right place. Β If you've done it, made it, got a van load of oily t-shirts and have decided to give something back by sharing your knowledge or wisdom,Β Β then you're welcome too.
Γ—
Γ—
