I'm at a bit of a cross-roads. I am on the brink of constructing a barn for wood storage purposes. I am not fortunate to be occupying a property fetted with land or storage space, rather I keep all my kit in the garage and paid storage near my house. As above I now need space and a friendly farmer has offered me a corner of a field to store timber for processing (no comments re this please). Point is it about 10 miles away and as I dropped off some wood at the site at the weekend I just knew it wasn't right. Not only does the distance put me off. The access is seriously muddy and I can see myself getting stuck in there regularly during the winter. There are enough other known negatives to pause me from investing a grands worth of materials in making this shed. Positives include remoteness - unlikely to get timber stolen and it's free.
I have a serious amount of timber to get "housed" and processed for firewood. I need yard space / barn / covered area ASAP!
I'm about to go out and start cold-calling run down farmsteads in my area to try and hammer out a deal with complete strangers. This aint my style but what else can I do or should be doing?
  • Replies 47
if ya gona use the farmers land, will he allow you to make a tracked road from woodchippings?
Exactly what I was proposing so yes, import a load of woodchip for the ground... :001_smile:
or im sure there are some tree surgeons near you that can tip some of for free or for a small fee as they generally dont have the space themselves for all there chips and generally give it away for free anyway.
just put a post on here and explain why you need them and im sure they will help out a fellow abrtalk member... good luck and let me know how you get on:thumbup:
i am in the same boat john, i have used up all my space that i have, it is only tiny anyway, on a slope and a triangle, so we have to take one thing out to get to something else and double, double handle everything, i am taking the jump and spending some money to rent a flat, square piece of hardstanding that is clean with security and electricity, it is very close to me house, the yard i have is great but only good for parking a truck and it is always dirty and dark in winter as its on a farm.
  Mr Ed said:
Using woodchips to make a road across muddy ground is insane. Want to make your muddy hole even muddier? use woodchips!
wot would you suggest?? Mr ed
:dito:
It wont work, if its already wet and muddy it will get worse, I've tried it:thumbdown:
I would look at getting some hardcore in, ask first though, work out the costs then go from there.
If its a bit of a nightmare to get too then it will soon P*** you off mate.
Demolition rubble as a sub base, strip off topsoil and turf. Track in rubble with excavator. Infill with sub 50mm, vibrate in tight and topdress with type 1 or road planings.
Anything else is just wasting time.
Read more
