4 hours ago, spandit said:
Thanks. Been a struggle with the council getting it approved but now mainly leaving it to bed in and attract nature for itself
Good job. Do you deal with the Wealden District Council or Mid Sussex?
What sort of planning did you need to get?
Had two Greylags on our pond this morning, a nice change.
WDC - it was a retrospective application. Took about 2 years and a lot of reports. Waste of time and money frankly.
  • Sad 1
  • 3 weeks later...
Still a work in progress, and with fingers crossed for the better few days weather forecast(since yesterday was a most depressing steadily wet day here) I will get it better finished with the wee Kioti and linkbox cum land leveller(since I have reluctantly concluded that I will never be a good enough digger man to please myself:blushing:)
I am not intending to sow out before this Aug/Sept at the earliest as it will need to settle, since I buried umpteen Couch grass "scraws", plus there are varying depths of loamy peat fill.
I found, pure happenstance, and externally fixed one leak, hiding behind where the glass house was previously located, they may be more, though no other signs of external wetness(but seeps/leaks could well be getting away through pre-existing land drains, plus some inevitable seepage, but as long as the water level remains reasonably high, no odds, I may simply never need to worry about an outfall .
The brown trout are well happy and it is a pure pleasure to see them rising for nymphs.
So a couple of images.
Edited by difflock
I can understand that. Yep seems like lots of paperwork to be able to put in a pond that is only going to benefit the council by improving the environment and biodiversity. I wonder if you would get more help if you had asked for a Countryside Stewardship Grant.
Nice pond there. Is it a clay base or rubber sheet to hold the water in? Or a natural pond?
An entirely constructed pond, filled with runoff water from various roofs.
With a Clay base, it should be "near-enough absolutely watertight", but the contractor was not entirely  diligent in identifying and setting aside the limited amount of less-than-suitable material, and being a very experienced local guy, he really should have known his stuff.
He also buried peat that should have been removed, and included in the peat was an undisturbed clay pipe land drain, which issued copious water when I broke into it.
Fingers crossed it should now be OK.
Edited by difflock
With a Clay base, it should be "near-enough absolutely watertight", but the contractor was not entirely  diligent in identifying and setting aside the limited amount of less-than-suitable material, and being a very experienced local guy, he should have known his stuff.
He also buried peat that should have been removed, and included in the peat was an undisturbed clay pipe landdrain, which issued copious water when I broke into it.
Fingers crossed it should be OK.
Clay ponds are good if done well. Not that I have ever built one. I look after one and the dam needs some good repair and with the recent continuous rain some of the dam washed away so had to do  clay repair to stop the water running out.
I take it you had a contractor in to put in a clay base and make it water tight? It will I am sure become a good place for an improved wildlife population which is always a commendable thing to do for the environment.
20 minutes ago, MattyF said:
Is the water dropping much in the finally the lack of rain we have had ?
Are the trout Triploids?
Not noticably, but I really must install a rudimentary depth gauge.
And yes triploids.
Nope, the impervious "blue" clay underlies the peat in this area, i.e. where we built the house had been  "rank moss", but long since cut-out for peats(turf), so the remaining 500-600mm or so of peat was to be entirely removed, then the underlying clay scooped out and built up to form the banks, with said banks built entirely on the stripped clay base, i.e. not incorporating any peat beneath them, never mind the tile drain! .
It should have been a simple straightforward operation  .  .  .
Edited by difflock
