I might have to get a custom grass knife made up for it as well [emoji6]
I think having a custom knife which sticks a bit forward but a long way to the side with a slight curve in it could be one way, although might be thought cheating.
So basically you want to stick a miniature scythe blade on the strimmer xD
2 hours ago, spudulike said:
Just caught up, you should be looking at the most powerful option out of the box and then port, muffler mod and use a head with extra long thick lines. I say this as you will need to keep the thing bang on the powerband and cut as much as you possibly can - perhaps make a special head with wire cable lines so you are less likely to loose one and cock up your chances.
Failing that - drive a steel stake in to the scythes path - he won't be so chipper when he hits it:D
Cheers Spud! I'm up for giving it a bash, I'm 6'4" so got some reach on me ? if I arrange getting a brush cutter to you, you up for porting it please?
3 minutes ago, spudulike said:
How about sticking a 1m hedge trimmer on a pole - should be effective or does it have to be a strimmer?
Lawnmower on a tractor - flame thrower:scared1:
Think it has to be a strimmer or close variant. Otherwise someone would turn up in a combine ?
I will give it a go. You get better strimming with a good length line so you just need to get the engine going as well as it can and then experiment in thick grass with different length/thickness line. I am wondering if a head with four lines would improve the cutting over two!
Power requirement goes up with the cube of the air thrashed about (roughly proportional to length of strimmer line) a large steel blade would sap less power and not send bits of plastic everywhere.
Isn't the whole point the scythe wins..?
I was thinking of trying both the largest grass knife I can find, and a modified Oregon Jet Feed 4 way head with different line types. Maybe something like guitar string, which has the little washer thing fixed on the end to hold it in place?
