had a slight accident today with a saw, and it didnt even last one round,
        20180602_163942.thumb.jpg.3827b6781289e13b42f78f5155ebb50f.jpg20180602_163957.thumb.jpg.3559875d0b42cac1d4911797caebd099.jpg20180602_164011.thumb.jpg.a42827f90b8fc7d8fb95f19304853421.jpg20180602_164022.thumb.jpg.864384dd17be92b76ff85490a0d12bce.jpgstihl vrs 30" spruce tree
I had that happen with a 395 on a 36" bar  .  Send it to spud if you are not confident to fix it yourself .
Edited by Stubby
if i had the parts here it would be up and running for tomorrow, but i aint got the parts so its a internet search night,
Ok . ?
Ouch!  what happened exactly?
Probably something like Crunch Scrape Smash Kipper Bang.......
........ followed by Bxxxxds Bxgger Bxxlox, fxxk it ....repeated several times over like a meditation mantra at differing volumes.
As long as no one hurt.
3 hung up windblown spruce all on the same root plate but trees stacked above each other, so root plate about 18--20ft high cutting the bottom tree got saw stuck so got another saw finished cut, when bottom tree parted from the root plate the rest of the root plate and trees collapsed and noway on this earth was i going to try and grab the saw hence it ended up being driven in to the ground with 2 big spruce sat on top of it,,, Oh F--k , 8 month old 461 so thats best part of a grand gone in about 1 second, but on a brighter note the air filter is ok . took bar n chain off and it started .
