Tom D
Rabaud F80 splitter
Has anyone used one of these? I’m still considering one but i’d really like to know the real world performance ..
Share this post
Link to post
No, I think I’d cut rings, crane 3 or 4 in and then split the lot at once. The question is will it handle knotty stuff into 28 pieces? It’s an 80ton push so it should be pretty good but i bet I’d you get a bit stuck it’s a mission to get it out.
Share this post
Link to post
That looks a helluva machine Tom for what it’s worth I’ve got a vertical tractor mounted Rabaud splitter had it for 20 years it’s been faultless built so strong it’ll split everything
but not In the same league as this big boy
i wonder if you could put rows of smaller logs in there like 30 or 40 at a time or have you got a large supply of oversized material
and have a loader and large bucket  on the end too catch the logs
Share this post
Link to post
A friend has the bindenburger version which is quite a beast but only got a 16 way knife and using it for big rings definitely is efficient with a smaller splitter sat next to it picking up any slightly too bigger logs.
Getting stuff stuck isn't too bad because you can get at the knife back with a decent sledge hammer and knock anything back into the chamber quit easy, if you were doing billets I think it would be a bit bigger problem.
One tip is do not stand in front of it as logs can get fired out at a rediculous speed when the pressure builds up!
Share this post
Link to post
There is a version which has a conveyor, but it’s a lot of money. We have lots of oversized stuff to do, we currently use a posch 30 ton 4 way splitter to split billets and these we put through the processor. It’s pretty slow and a lot of double handling. I’d prefer to ring it up with the 66, maybe even buy an 88 and just push them through that sieve.
Share this post
Link to post
9 hours ago, Martin du Preez said:
Those split logs look a bit on the chunky side?
That would be my concern.  Can sell logs that size Tom?
Share this post
Link to post
There’s I think they look ok, it’s the long ones customers don’t like.
Share this post
Link to post
Looks a beast if you can sell that chunky a log. At the best part of 3 tonnes per split I wouldn't think it should't get stopped buy much.
Edited by Woodworks
Share this post
Link to post
