On 3/22/2018 at 15:38, benedmonds said:
Our Bandit HB20 is giving us problems.. apparently it runs fine for an hour or so then dies... It was dropped on its side a few weeks back..
Any ideas?
Have you checked the battery/charge system? Mine was playing silly buggers after I replaced a burnt out coil, later discovered I had put a connection back in wrong. The battery didn't charge and when it ran low enough after a bit of grinding it would give up. Earliest symptom I got was the electro clutch not engaging. i assume the same thing would happen if the battery was damaged during the roll over.
