6 minutes ago, eggsarascal said:
That doesn't look good. Have you managed to pull it out?
Yes, we got a strop- thankfully my digger pulled it out, but was touch and go. There Was a spring bubbling up under neath the tractor so we turned it into a Curlew scrape! Think he was feeling a little sheepishxD
Yes, we got a strop- thankfully my digger pulled it out, but was touch and go. There Was a spring bubbling up under neath the tractor so we turned it into a Curlew scrape! Think he was feeling a little sheepish[emoji23]
Nice one. Looks almost deliberate!
29 minutes ago, peatff said:
Did you unhook the trailer to get it out ? They do cause problems in soft ground.
That would have been ideal- but the hitch was so buried I couldn’t drop it off. The trailer has flotation tyres on which helps and generally goes across pretty boggy ground- the bit the tractor went down in was essentially a pond covered in spagnum moss!
