You need to remember why OEM parts are relatively expensive - I got through two MS660 Chinese cranks before the owner asked me to fit OEM and it hasn't come back for a long time. The Chinese ones lasted months - as below, the other one threw its big end and unusually, it didn't do the top end in.
Just assembled my 372, going to wait until the morning with a fresh head to set the carb and fire her up. I also have a surclip left over, so I'm a bit worried.... :)
Apart from a bit of a fiddle with the oiler, it went together perfectly. The start coil quality is crap mind, so if anyone has a 365/372 genuine starter assembly for sale ....
Will upload some pics in the morning.
i have just put together a hutzl 372...i just swapped out the recoil internals for oem and it feels fine now. i also put a oem brake band on as well.
be good to see how it runs :thumbup:
Just before I fire her up, H/L low screws where done all the way in then 1 turn out, idle screw I'll do when running. And Dan, just checked my flywheel nut :) The video i followed used a washer on the flywheel but the parts diagram doesn't have one, not sure what direction to go in there but as I dont have a torque wrench I think I'll washer up!
What circlip - did you 100% fit one either side on the piston? If you didn't, it will detonate and take the top end out!
Ah, okay guys I cheated, I ordered a seperate crank case already assembled so I have all the parts to make up a new crank case (plan to do this with original bearings, shaft, seals and a 52mm cylinder).
So yeah, that surclip is "engine stuff" that was already built 9_9 I'm glad your online Spud, watch this space as I spend all day trying to get her to run :)
Do you usually put washers on flywheel nuts?
