Have a 440 what wants a bigger bar. Currently on an 18 which cuts well but basically want bigger for dismantles. 24 or 25 seems a bit over kill and clumsy and 20 seems not much bigger than 18.
Thoughts?
I run 22" in small/med windblow and as the actress said to the bishop - every inch counts - It's no big deal asking for a 77 dl chain if you have a saw shop near ? or if you make your own  chain. When you have used a 22 it almost makes a 20 redundant well in my line anyway !
we run 22s as standard on our 361's, 440's, 460's 660's and 661's (I hate carrying alot of different size chains)
Its a common size here for forestry. run 8 pin in the 66's and 7's in the rest.
Good size
Edited by Timbermcpherson
I've run 22's for a bit when I got some on sale. But if you are basically just blocking and limbing, the 24/25" will give you some reach and be easier on the old back. You can also then get the Stihl E laminated bar which is rather light, and a bit more affordable than the ES version. If you do not bore cut much with it, it should last a good while. I also think Oregon has just introduced a laminated aluminum sandwiched bar in their versicut model that is affordable, too. It weighs nearly a pound less than the ES series.
Just looking at filling a gap really, have a ms361 on an 18" and 660 on a 30"
Really I'm talking about a climbing chogging down saw....get hacked of lumping a 660 around when it's over kill, also trying to avoid shuffling around other side of limbs/ stem to finish cuts off on take downs.
Read more
