9 minutes ago, Rwhiteheadfirewood said:
I'm thinking the 10x5,6 ifor would be a good choice for me as hopefully I could get 3-4 bulk bags on it and still move my bobcat around too
Ive a 10 x 5 ifor tipper. I get three bulk bags on as standard sides and with the mesh sides i can get 4 potato boxes worth tipped in which is 6.8 cubic metres
That's what we've got, we replaced our previous one 5 years ago and both were good trailers.
4 bags might be tight unless you drop to 85cm size ones.
I had a 10x5 ifor tipper with the cage sides, a great sized multi purpose trailer. I'd love to deliver a bulk load to the tops of the cages in one but I don't think anyone round here would be prepared to pay for it!
i will be buying another when funds allow
I moved my 1.5 ton digger on my tipper loads, it's a bit less stable than a flatbed and obviously nowhere near as good as a wheels on the outside plant trailer but perfectly usable for moving machines.
5 minutes ago, Rwhiteheadfirewood said:
Thanks for replies chaps. I'd only have the normal sides as wouldn't need the mesh. The bobcat weighs 1.5 Ton reversed on right to the headboard would be fine I recon it would only get moved maximum 5 times a year about 5 miles so not far.
As I said balance, you may find you have to much weight on draw bar if you back it on.
