Thought id share some pictures of the past few days job, 2 days felling and chipping 25 trees at one adress, and today using the Kranman to extract about 100 logs in 4 hours, then another adress of 15 trees/50 logs, think its easier to answer questions if anyone has any about the machine than ramble on :D
IMG_3604.thumb.JPG.fe2de2e8d9e55e3fdc840889c70e5523.JPGIMG_3605-1.thumb.JPG.83d20d5d8474c3368bee2e52baae584b.JPGIMG_3607-1.thumb.JPG.e81ae41cf9db6c2efba1dd6bf214a693.JPGIMG_3608.thumb.JPG.4333897435814f6a94d64e332b59e1b5.JPG
IMG_3612.thumb.JPG.35c21bf0a5be9efa271279527aa5b26e.JPGIMG_3613.thumb.JPG.7c1444683c32ccdcc1d7a6caff05826a.JPGIMG_3614.thumb.JPG.65c83d1408c315392e26bfd5b2d63733.JPG
13 hours ago, Pete Mctree said:
Looks an impressive compact machine - perfect for such jobs. What is it like on steep terrain?
Not sure pete, only had it in gardens, drove out via a quite flat woodland to the side. needed the rear drive when loaded to get over relatively small obstacles or driving over wood chip loaded. Not as stable as an alstor
14 hours ago, MattyF said:
What's the cost new??
I think they start around 20k +vat, but once you've added the extending boom on the crane, radio controlled winch on the crane, plastic cab, heated seats, joystick controls, work lights, etc etc its over 30k
Certainly interesting to use, and perfect for these jobs
  • 6 months later...
Had it out again today, and tomorrow too.
get more and more impressed each time I use it!
This is was this afternoons work, 4hours, 100-400m extraction route 5E358335-5403-49BA-9994-F84DEB42AAF3.thumb.jpeg.3d66d89811bc75985bb0f4e95eaff98a.jpeg
Yeah they’re getting expensive, then again alstor has jacked their prices up too! Too whack alstor here is over 80k!
Id like a go on the diesel 8000 bison, see what the difference is. This 6000 seems thirsty (might only be noticing its consumption as its running aspen mind!)
