Hi Nikk the newbie here out of shear curiosity how do you decide on what chainsaw to use on a job ? And which would you buy?
Don't worry as a newbie I ain't buying!!
Cheers Nick.
  • Replies 52
Apart from the excellent advice already offered...I use the lightest possible saw that is big enough for the task. Husqvarnas all the way for me, but whatever brand you use , similar principles apply. 15" softwood? a 346 is fine. 15" hardwood I'd go a 365. If you're regularly getting into bigger stuff like hardwood firewood >20" I would consider getting something with more power. You learn when a saw is struggling so why push a wee saw to its limits? I also recommend using the shortest bar as is sensible. I never run the max size bar for a given saw as default, only when totally necessary e.g. a massive tree, I've got a 36" bar which goes on the 395, but then I'm straight back to something more sensible like 24 at soonest opportunity.
  Steve Bullman said:
You just take at least 6 saws everywhere with you and use whichever you fancy at the time :)
I've only got 5 :( Better start looking round. What's the difference between a CS-352ES and a CS-361WES apart from about £50 :thumbup: For me these days it's the lightest thing that will do the job as well :lol:
Meant to say...if you're only getting one saw, I would go medium range around 50-60cc, you can get throufggh a lot with that and its not too cumbersome. German or Swedish, whatever floats your logs.
That's good advise :thumbup:. Id be tempted to go for 70cc if you are cutting hardwoods a majority of the time though.
I love my 372xp :thumbup1:
As said the lightest one that can do the job . Having said That , there is no law against having as many saws as you want ..........Start at around 50cc and work your way up to 60c , through to 70cc then on to 85/90c and up to the 3120/880 territory . You wont go wrong there ......:biggrin:
Edited by Stubby
Read more
