  • Replies 31
Hi guys checked everything on the recommendations, still no result, one thing I have found is slight play in the bearing on the flywheel by the rollers, would this be enough to through the sensors out?
Check voltage to Solinoid,check connection plug to Solinoid
Check that you have two green lights on the computor circuit board at full Rpm and a steady orange light.
With the igniton on and engine not running,rotate the Pulley so that one spoke is inline with the speed sensor-does an orange light appear on your circuit board?
Reset your Auto stress.Run Engine up to full revs,press top and bottom buttons simultaneously on circuit board untill red light flashes,drop revs 30% and press bottom and middle buttons simultaneously.
See if you can borrow another circuit board,I have had them that showed all the right lights and even reset but after 10minutes failed to work.Running 12V to the posts on your solinoid and not to the plug will tell you if the problem is electrical or mechanical
This is just the Electrical aspect.You could also have
Knakered Hydraulic motor
Low Oil
Broken linkage to hydraulic valve bank
Good luck! You will get it sorted
On mine the taperlock on the cast iron pulley had a hairline crack allowing it to move along the shaft. This increased the gap between the spokes and the sensor, it also allowed the blades to contact the anvil eventually.. worth checking. The taperlock should have one split in it along the radius, not two!
