Looking for a new welder soon.
Want something that can weld 6-8 maybe 10mm
Currently have a little clarke 150turbo but is only really any good for up to 6mm
Back in my days at a garage i used to do all the welding with either a 245 or 275 amp welder though cant remember the make.
Can i get anything reasonable for 500.00?
Any reccomendations? Cheers
  • Replies 29
Cebora make mig good welders for a lot of big names as well as their own brand, the snap on 130 is a cebora.
Have a look at the wire feed assembly, some are plastic which flex and give no end of trouble, like the SIP I used to own
I use a SIP 181DP which will kick out 180 amps on 16amp. I run it 13amp so it maxes out around the 130-140 amp range. The duty cycle isn't very good. But being dual polarity it does give you a range of options.
My favourite one in the workshop is the BOC transmig 180 but that is from the 1970s i expect. When it dies it will be a sad day because spares are very rare. The 250amp quasiarc company welder died recently:thumbdown:
For a new one I'd get an Rtech one decent price duty cycle and quality.
180amp range will do 10mm but you will have to V prep it and do multiple passes.
Chris I would sooner spend the £500 on a quality secondhand machine ,as Tom suggests a decent Murex or if the budget would stretch to it get an Esab.
Bob
Hi Brush cutter, you mean the 180 inverter?
What does the inverter do?
MIG Welder | 240v Portable Inverter MIG Welding Equipment I-MIG180
150amp ish from a 13amp socket. If you have a 16amp socket then even better you'll get the most from it. Unless you want to do serious big welding and lots of it then it's not worth the hassle of running a 32amp socket from the board to where you want to weld which would let you run 180amp plus.
The inverter first changes the current from AC to DC and then transforms it to desired welding current. Technically the transforming bit is inverting and the AC/DC bit is rectification.
If a supermig 200 is a 200amp machine for around about 300 quid i doubt the duty cycle is very long and a i expect it's not very good.
