what they use to use.
kinderscout
It was state of the art at the time !!! just think yourself lucky you were born when you were and have not had to use one of these ..... most probably the same will happen in another few generations when some one unearths an "old " ms 880 ..or ms 200 with a "petrol engine" haw haw ......
Nice german made Solo.
At first glance it looks like a 635, which was about 90cc, relatively slow revving by modern standards, 5-6HP range. The "chain brake" is interesting! I might be way off, but I used one (635) 25 years ago in Zimbabwe and it looks familiar, it was "oldish" then (early 90s) so probably of 1970's vintage.
I've a vague recollection that the orange/white version was a Super 635 and had it's own model number (642?). There would have been an ally serial & model number plate riveted just below the fuel cap, might still be there hiding under the accumulated sludge?
Hopefully a collector will be able to correct my errors/give you some informed opinion!
Did some Googling and found a chainsaw collectors forum with some nice info and photos of various Solo 635's.
Here's a couple of links:
-Solo 635, 636 (60135) - Chainsaw Collectors.se"]Link 1
-big solo question - Chainsaw Collectors.se"]Link 2
[i'm having a bit of trouble with embedded links, if the above don't work try Googling this> Solo 635, 636 (60135) - Chainsaw Collectors.se Solo 635, 636 (60135) - Chainsaw Collectors.se[/url] 635, 636 (60135) - Chainsaw Collectors.se 635, 636 (60135) - Chainsaw Collectors.se].
And lastly an old Solo ad with some specs. HTH
