Domestic insulated power cable
hamdogg
Evening all, I've recently been to look at a job which consists of taking a sycamore down, but it has a insulated power line that feeds 1 house through edge of the canopy,
With this being insulated am I right to say it's still a no go?
Cheers
  • Replies 21
You can work within 1 meter, and if that's still no good then phone the power supply and they will send there engineers out, thay won't isolate it as there's no need it won't cost you a bean there just there just in case
So they cant do anything anyway? Might as well just crack on wid it
Just put a request in for shrouding and when they come back and say no need your covered but as you will be working about a live powerline I'm fairly sure you have a obligation to notify them.
It's free and unless they require isolation normally very quick.
Also I've had lads turn up to isolated lines for me and persuade them to disconnect the section and drop it which has made our job so much easier and quicker so they get the line back up and on faster.
Fines for damaging the lines are eye watering apparently so go carefully
Sent from my D5803 using Arbtalk mobile app
Read that last line carefully.
They are....☹️
This quote is a bit misleading. if you are trained to and have permision from the relevent dno then this is true. If you are not then you should not work within 9 metres or 2 tree lengths, (whichever is greater) of the conductors.
