Sign in to follow this
David Humphries
Landrover 130 stuck in 1st gear ?
Receiver cup in the remote has moved as athe allen screw has come loose.......................
This sounds like its from experience ?
Share this post
Link to post
Had a similar problem with mine. Could be the slave cylinder. There is a nut that you can release the pressure, you then top it up with dot 3 or four and continue to pump the clutch until the pressure builds up. Always worth a go and it's a cheep stating point
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Note: Your post will require moderator approval before it will be visible.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
