  • Replies 52
No, that's just silly, I was replacing a broken part, any additional power is a bonus, as long as it pulls its all good... I have thought about a bigger compressor wheel with a matching remap on the pump, mostly so I can tow a trailer full of canvas marquees over the summer. the front is having a winch bumper and spotlamps, no space for anything else... and the only other upgrades will be the brakes (twin pots off the warrior) and front torsion bars.
Sent from my HTC One A9 using Arbtalk mobile app
Erm, you seem to have forgotten your gorkel (gay snorkel)! :-)
If you can mount it on the front rather than the top , it'll probably give you an extra 40bhp. Then you'll need a new clutch, then better brakes, then a bigger turbo then the fuelling will need to be reset after that you'll need to beef up the suspension. Give it a fortnight and it'll feel slow again. Then it'll be time for a.................
Uprated prop shafts and diffs to handle the power:biggrin:
top mounted intercooler= engine heat soak, if anything you'll actually start to loose power as the engine warms up, get it mounted in front of the radiator and re-pipe it
