All stump vices are shite.
Some are more shite than others I suppose. If you must have one (though I can't see why you'd ever need one?) make sure the screwy bit has a handle or lever, not just a thumb screw or it'll never ever clamp tight enough.
If you already have a thumb screw type vice, drill a hole through the flat bit, and put a small bolt through it for added leverage.
