Been using the Oregon anti fling oil but in this cold wether I'm finding it too thick and not getting through quick enough. What do you guys use? A few folk have said to use engine oil as it is cheap and will get pumped through quicker.
  • Replies 32
The heat of the saw will warm it up, so I don't really see how the weather affects it once its in the saw.
Sure its slow while refuelling, but no real hardship.
Been using Oregon bio oil for 10 years or so , no problem until I bought the Ms 150.
I've switched to dolmer oil now and that works for the 150.
Here in winter ( Berlin ) we regularly work in temperatures below freezing.
Yea everything is working as it should be. Some to a boy and he reckoned working in cold weather, especially cutting hard wood engine oil is better as its thin and doesn't block up
Use rapeseed oil. Better for the environment, better for you, cheaper, doesn't clog up like the bio oil from ex. Stihl and is thinner than regular bar oil. Remains liquid down to -20 C.
And cakes your saw with burnt on layer of crap. Stopped using it. Longer bars don't like it either.
