Skip chain stupidity??
TheHungrySquirrel
  • Replies 37
We now have full skip .404 .063 semi chisel 27AX Oregon Full Skip Semi Chisel .404 .063 - Chainsawbars
Full skip chisel 3/8 .063 75JGX Oregon Full Skip Chisel Chain 3/8 .063 - Chainsawbars
Full skip chisel 3/8 .058 73JGX Oregon Full Skip Chisel Chain 3/8 .058 - Chainsawbars
Be careful of modifying existing chains with a grinder - it can weaken the chain on that cutter. I snapped a couple in the early days doing this...
:blushing:
Rob those 3/8 058 chains fly, that 16" I got from you is an animal on my 372.
Are you able to offer any advice on the 560 3/8 conversion??
I think you will need the clutch side cover from a 562 to make room for the 3/8 drive . You will find though that if you run outer dawgs on a 560 they wont fit the 562 clutch cove as the mounting holes are further apart .
Seen a bunch of people running the 3/8 and it seems just a sprocket and bar/chain is all that's needed.
If there's a way to get a 562 case and dawwwwwgs that would be awesome.
This saw doesn't get to much use so want to make it a monster with full wrap and skip chain.
