I always think about getting an alpine magnum but have never committed... Looks like hardwork..:001_smile:
I reckon I'd have that done in less than 2 hours with the Magnum. The longest part is digging the soil away from around it as the magnum teeth don't last too long in the dirt and cost £60 a set. It's bloody thirsty too with a Husky 3120xp head running on full trigger. They are a very capable machine though and ideally suited for jobs like that. With a set of new teeth, they cut wood at a rather alarming rate! It's a shame you're not a bit closer or I'd have been able to help.
I also suspect I could get my Rayco 20hp up that slope as it has some very treaded mini tractor tyres on and has dragged me up some very steep hills!
Starting off is a bit slow, but the spoil quickly provides a work platform. It's hard to tell from a photo though.
The beauty of the magnum is that it mounts on a single spike, so you could attack that from any angle. It's a different technique where you need to cut down along the grain rather than sweep sideways like a conventional grinder.
They are hard work though and not a machine for the faint-hearted!
SG
  • Replies 30
I've taken advice from hundreds of my domestic customers on this one and apparently if you cut some grooves in a crisscross pattern and/or drill some holes in the top of it, it will disappear in about 25 years.
Only if you then add creosote though!
Stumpy Grinder is right.
I would use my Alpine and a chainsaw on this.
First clean around with the Mag, than cut as low as possible, then grind the left roots with the Alpine, should take 1-2 hours, probably less.
