Lights and front mounted equipment
Gray git
I have recently changed tractor to a valtra that has front links which has allowed me to carry a timber winch on the front but this then obscures the lights. I can flip the headlights from nose to top of cab on a dash switch but now do I need to have some marker lights on the front of the winch?
Sent from my D5803 using Arbtalk mobile app
Couple of these up front should get you noticed [ATTACH]215518[/ATTACH]
Sent from my SM-G900F using Arbtalk mobile app
Emmm not sure why you have a picture of that so readily to hand to share 🤔
Did think a decent warning sticker might be enough
Ermm I was definitely looking at them as a present for someone else and that is not my bathroom!!
I think you reflective strip would do the job.
Depends how often you are traveling with the winch on front as to how much effort you are going to make.
You could probably get some sticky marker lights
I reckon an ally plank, fitted with headlights and indicators, couple of bolts with wing nuts so it can sit on the front, bolts through the chain slots.
It's not just about seeing, your winch makes a fair distance between drivers eyes and the first thing to creep onto a junction/ blind corner/ etc
Sent from my E5823 using Arbtalk mobile app
Did you not have a roof mount before?
