  • Replies 32
Nice one :-) not seen the plastic handles before! So they take mallet splatter well?
A timber insert would last me about a year if I was very lucky but had the plastic 1 for about 3 years now and apart from annoyingly bouncing out the alloy it's almost indestructible.
Sent from my D5803 using Arbtalk mobile app
I use a couple of the medium plastic wedges at the sides then a highlift in the centre, sees most stuff over that doesn't need a pull.
Usually the Lil plastic wedges are only any use for taking big stumps right down (if you can't find a stick)
3 wedges? Personally I find that excessive (not knocking you) there's not many trees you need more than 2 high lifts... Imho
