What Marc said.. Im using 4mm cord to make a small friction hitch off the d plate on the treemotion. Easier, lighter, cheaper and more gangsta :D Will try to get a picture if i remember.
Better late than never 😉
And before anyone says anything it's not bee line being used it's arborplex which according to retailer is safe to use
Sent from my D5803 using Arbtalk mobile app
Sorted it now👍. Got meself the Ropeman 2 with the tiny DMM spring gate (rated at 4kn). Job done.
Thanks Mr Git and MattyF for your help and advice.
4mm accessory cord. clove hitch on the stopper knot side of the plate, over to a tautline, then closed the tails together with a double fishermans. Does the job nicely.:thumbup1: I only shorten it for a long ascent really.
Neat rope work 👍. (Fair bit cheaper as well!)
  • 3 weeks later...
I have been looking in to this for a while but not been brave enough to tinker with the original fittings, so was wondering if just for ascending using the hitch climber any one had used a short sling for example a rescue strop, attached to some kind of ring on one end and threaded on to the bridge, then clip the Dmm oval on to the other.
Not sure I'm making sense? But I carnt be the only person needing a bit more room between me and the hitch climber pulley?
Cheers
I used a Lyon sling before to give a bit of distance between me and the hitch climber, also had a go with the o rig which enables you to adjust the distance while climbing without the need to unclip a sling
