  • Replies 103
I find that I rarely use the side D's on my TM, instead I use the lower D's. It's seems to be how the design of the harness has influenced my climbing style. I use a zillon as a strop which is rated for life support.
I recently LOLER 'ed a harness that had a back up bridge.
A Zillon is rated as life support, would you want this as primary attachment at the end of a branch?
An ART positioner which I use is a work restraint lanyard and doesn't in my eyes make a life support
Taking time to get a good work position is what's needed not a second bridge!
If your worried about your bridge are you not worried about cutting your climbing line... i personally have not heard of many people cutting there bridge.
Sent from my SM-G900F using Arbtalk mobile app
It was actually a loler inspector who first put it too me about the TM bridge being fragile when it came cutting implements grazing it.
He did comment he had seen some back up bridges on other TM harnesses,further to that ive seen a couple of climbers on facebook/instagram etc with what looked like back up bridges however seeing those pictures posted in this thread with harnesses with in built double bridges perhaps it was those ive seen.
Definitely not at the end of a branch, obviously. But, working at the end of limbs means that you would be cutting well away from your bridge.
If I'm advancing through a large open canopy tree, I will often use my Zillon as primary support.
Getting back to the original subject...
I feel much safer on the Treemotion bridge than I would on the Buckingham Ergolite with its "Wickes blue polypropylene" looking rope bridge.
Two bridge attachment points opens up better work position options than just a lanyard alone.
there have been a few well documented bridge failures, mostly where the original bridge has been replaced with incorrect matterial
Looks good Craig. Any other pics?
On the double bridge issue, the New Tribe Onyx has the ability to easily add in another bridge and their Nikosi harness has a built in twin bridge.
thanks
the onyx uses a small rigging plate for attachment, so if you put a second bridge in, there is no other lower d attachment point
never tried the nikosi but its looks a bit 'different' in concept
Maybe this thread would have run in a different direction if it had been about a second bridge for work positioning/climbing, rather than as a safeguard against failure by cutting.:confused1:
true:thumbup1:
That's very interesting.
Do you have any links please?
Thanks.
