  • 3 weeks later...
On 11/13/2017 at 14:11, Stumpy Grinder said:
I recently started using a Diamond Wheel in the bench grinder!
https://www.abtec4abrasives.com/d1a1-150-mm-x-20-mm-x-3175-mm-diamond-abrasive-grinding-wheels-413-p.asp
They are not cheap, but it has transformed the process of sharpening teeth to whole new level! No more horrible green dust and the wheel lasts up to 20 times as long! I've done hundreds now and I'm still on my first wheel.
Not only that, it does them in a fraction of the time and they are sharper than new ones!:thumbup:
SG
Is this diamond wheel "safer" in terms of less-toxic dust?  And if used to sharpen greenteeth is it the right diameter, thickness and curve to create the correct concave finish?
  • 4 months later...
SG
Hi Stumpy... which coarseness of wheel did you get?
