  • Replies 33
She's still popping out.
Returning to the tank now and not through the spool.
Fitted a new male quick release coupling, incase it was worn.
If the flow rate from the tractor is too high, could this be the problem?
Absolutely
It's not something I have experienced, even with a quick release supply to a FAE mulcher.
Does it get hot at all?
I have, someone robbed the PTO pump off my trailer the only spare I had was running a side arm flail and massively over size. It was practically unworkable but it served to get the legs up and crane stowed.
In hydraulics, too much is not always a good thing
One spool is adjustable, I will need to try it screwed right down.
