  • Replies 60
Nice to meet you Marc this weekend.
I just stick to the pinto top tie, but until something else crops up that I find as easy to setup , I will be watching this space.
good video - going to try the multi sling one - like that it can be advanced and retrieved from the ground even if through a few redirects too
i don't own a multi - sling, but guess its ok to put a carabiner through one ring of a cambuim saver to achieve the same reposition capability
Edited by tree-fancier123
This seems good.
Starting from 4 minutes 20 seconds.
The last one is what I use although I have the carabiner gates opposite each other so at least one should always be away from the stem/branch/whatever regardless of the direction of pull. Not sure if anyone else thinks that's a good idea or not but makes sense to me. :001_smile:
I have been using the singing tree quickie found its works really well can be a bit tight with larger diameter ropes but is handy if you want to move your tie in point.
Sent from my SM-G925F using Arbtalk mobile app
Is the slic pin type thing attached Ewan? Reckon I'd drop it quite a lot!
Been trying this lately.
I tried that today abd really liked it. I'm always wary of the carabiner side loading but this great cause its closed off.
