  • 3 weeks later...
  • 1 month later...
A bit of landscaping around a new tennis court, had to lose the clay spoils from the court build and import a few hundred tons of top soil to cover it. Will be seeding this and there is a planting scheme but for the moment we are just getting all the gear in before it gets too wet.
0861E6E7-E0CF-49F4-8748-61E4BF9BF694_zps
6829F1DB-F3CA-4C11-B319-1B899C0FFF27_zps
5F36A2F0-3616-4743-A68C-044D48527873_zps
A2692736-736B-445E-B55E-E886833DC6A8_zps
D410D552-DEDF-4161-A7CE-222014C54C9B_zps
E9F01DB8-CB5A-4AB0-8935-2832CE41AE62_zps
  • 1 month later...
That’s a bit of kit and some! Can you hire those from anywhere? Would have saved me 2 weeks of trying to become a shaolin monk this year..
Nothing fancy here, just scraping up the mush and a few loads of crushed with fines in a loading area.
EF670A87-ECE0-49B6-8A62-7716600C6967_zps
Another small road just started through a RPZ , will be using the protector web as on the first page here. This one needs to support STGO`s so could see trucks north of 60 tons drive over it.
5A86C061-15AB-4268-A8B2-736D208EF4C3_zps
178F95B0-F509-4ACA-AED5-8AD4C25F45F5_zps
Rain held off long enough for the concrete in the entrance to set.
E1BAB307-55B4-495C-842E-6DB34B444E21_zps
29D36B8D-1780-4920-A479-6DA712BB3AFD_zps
Was this an existing road access or a new one?
Just wondering about the hoops you'd have jump through with the HA to get a new one
For a new access, then you would need a section 184 license for the access and possibly a s. 171 license for the works on the highway verge. It might be that the highway authority uses a s. 278 license instead. If it's a classified road then it will probably want planning permission.
The highway authority will probably want the access building to an agreed spec. It's likely to want to be a commercial spec access due to using vehicles larger than a domestic car.
I used to do a fair bit of stuff with vehicle accesses. Happy to try to help out if you want?
