Another footpath the lads are doing, just needs fines on top and rolling.  2mts wide x500mts long. timber edged , sub base, sand, terram , 4"of  limestone.
Edited by aspenarb
  • 3 months later...
Another track the lads have just finished, as you can see they have scraped it off level, brought in the sides and topped it off with scalps :D
Bob
F23904EE-7EFC-468F-A2E4-AD280B63861A_zps
  • 1 month later...
A small woodland walk of about a kilometer, sub base, membrane and scalps with no edges. Just needs a rake and roll on the way out.
Dinky little temporary bridge  out of concrete sleepers to get the machines over.
8436EBB7-0AE1-4F91-B698-FEBA064926C9_zps
CF3B5970-DF25-4EA1-9953-8583E339545C_zps
9CF5D06D-9F2D-416A-8499-9C2AF321CBC5_zps
CF04AC46-986D-4B33-A895-D77AD29D0703_zps
8548523F-979C-4C19-8289-7A87E4ADC1A4_zps
E71856BE-B886-48F2-909B-1B29409D3BF8_zps
And a steel fence + a load of kissing gates to keep out the hooligans.
761FB925-D4E9-478A-9CFE-A1FAF47F6C6F_zps
Edited by aspenarb
Better than my drive, that! Out of interest, can I ask what sort of cost per metre are we looking at? (For something that will support a reasonable amount of car and van traffic...) Thanks.
Not so sure you would want the sort of tracks/roads we put in at home. Most of these are woodland or country estate tracks/roads,  last one we did at a house was hundreds of meters long and about 4mts wide with railway sleepers for edgings. That came out at about £60 per linear meter for sub base, membrane ,scalps and sleepers.
Last 200mts before the road we topped off with planeings
  • 2 months later...
A few hundred meters of chain trenching we did for a shingle land drain from a waterlogged/blocked roadside  drain to a brook . The three ton diggers on site were struggling with the rock hard ground, chain had it all done in about an hour.
Bob
D337D674-F48A-4DB5-AD18-B8D353ECB601_zps
  • 2 months later...
The lads  renewed app 160 mts of these gurt 1mtr dia land drainage pipes under some roads and across a field. 6mts deep at the end so sandbagged/pinned  up to about 3mts and raked the ground back on top.
8FCECF2E-7565-4D2B-90CF-6CD023A0BEF9_zps
170B8DB3-4C53-4581-8900-F65AE77E8546_zps
Also doing a bout a 100mts of bank reinstatement/retention  around a lake with gabions
8ADC0C68-9740-4ABB-833E-CF1B4743FC78_zps
And a 13mtrx10mtr factory extension base + sewage treatment plant. Having a bit of a run on these @eggsarascal
this is the fifth one this year.
7CB4DD0A-B958-45A9-BBEA-C54E2B5A9F4A_zps
92B5035A-25BE-442C-A4CA-45DD25AB7E35_zps
5A00AD5D-A5F1-4890-9D00-46BE14E67C80_zps
915FB1C3-A599-499C-8088-E1CAA862245E_zps
E5C8A6F2-8B93-48C3-B7B8-5FAAB897672B_zps
Have you put a maintence programme together for annual servicing of the treatment plants?
The surface water outfall idealy needs a concrete pad for the water to drop onto to prevent the ditch getting washed away.
Edited by eggsarascal
Bloody amateurs, should be consulting an expert, shouldn't they Eggs :001_rolleyes::$
(Learnt my lesson after spending a couple of days trying to attempt to unblock our blocked drain before being told it was the utilities problem by eggs like....:lol: sticking to trees now.)
