You could try making your own custom bit with a lump of metal-reinforced epoxy putty. Lightly grease the bolt head, form putty into a cone and push it in, making sure its well packed and has enough of a handle to turn. remove, allow to cure and then use.
  • 5 years later...
  • 2 years later...
i also have need of a key to remove the exact same bolt on hundreds of meters of fencing. i have spent days online trying to find one and this is the closest iv'e got with a picture of the very same bolt, i would appreciate any help in naming the bolt or the name of the bit to remove the bugger. Cheers
