Sanding sounds like the thing to do then polish to remove sanding marks or splitting it thinner as paint has soaked in!
No idea really!
How thick are slabs?
  • Replies 28
No, a blow torch will damage the slate. I tried it once on an offcut when I was looking for ways to clean something off of a roof slate.
i suppose because it's a sedimentary rock it can split fairly easily. at least now i know that for the future.
It seems like removing the paint is expensive and could involve a lot of hard work. There is also no guarantee of the results...
How about seeing if the local architectural salvage yard has something similar?
I'd be trying petrol to remove it. Or leave it outside to the elements for a couple of years.
Acid? Just wanted to say I've had my service done With Servicing Stop and they are really good! They picked my car up from mine on time, took my car to a local garage, called me up to confirm anything that needed doing and dropped my car back off to mine, all within the time they said! Quick and easy, would recommend to anyone who has a busy life or just in general!
Always good to see someone join the site to recommend a service that has nothing to do with the thread....
What's for tea tonight? A nice SPAM fritter?
Bottom right of each post is a small triangular button to report tasty meat based foodstuffs :thumbup1:
  • 4 weeks later...
Just seen this thread, very fine sandpaper and lots of water will bring up a good surface. To short cut with elbow grease.
It doesn't need sealing for a hearth. We haven't sealed the slate hearths we have.
Slate is metamorphic, basically baked and compressed mudstone/shale.
The risk with heat and any rock is trapped moisture becoming steam and exploding.
Good looking slabs, probably set you back £600+ in a salvage yard.
