I used to use Timbrel but I just checked the Pitch care website and have found like a lot it has been withdrawn by HSE! They are reccomend in SBK which you can get in B&Q (other stores are available) I have only used SBK on Ivy with good effect. More research is needed!
Have you tried pastor ,a broadleaf specific weedkiller. If you want a really potent killer you can mix it with roundup but it will kill everything. ( assuming they haven't banned pastor recently as well )
SBK will do the job fine. It's safe on grass and as it's a consumer product you don't need a CoC.
You need a licence to do it commercially not to just use commercial products.
Diesel. And if anyone with a clipboard and yellow vest shows up, you're the homeowner.......Not really. Strong roundup will kill brambles forever. Saplings should be pulled up or lopped right tot he ground or they'll bother the strimmer for years to some before the rot.
