Lifting Bars
donnk
Looking at getting a set of these made up. Lifting pallets with straps nearly allways ends up breaking the pallet.
Anyone use similar for lifting pallets with hiab's ?
So if you have them made up will they be tested/ inspected etc?
If not and something broke and someone was injured then you would be in trouble not to mention having the injury or worse on your conscience.
To be fair u could still strap right under the pallet just run it throu the bar at the ends, mibee better with open loops then and mibee 2 catchers on underside of metal so strap can't slip forward/back, so u could slide straps in them.
So strops still under pallet and pallet strengthed by ur 2 metal bars
going to bore a hole in each end to hook into from the 4 hook sling. each of the 4 arms of the chain are rated at 1t. nice and adjustable for blocks/bricks/tiles etc. Allways lose some tiles when just using strops through the pallet.
Over the years I've seen several welds let go through lack of penetration, many cracks due to fatigue and poor manufacture resulting in high stress concentrations. This is why I was thinking best to buy the correct items rather than get joe down the road to make it.
I'm sure a short piece of scaffold piece would do it especially if kept short and has had an event free life.
However from the replies I wonder how many of you bother with LOLER.
