Personally I prefer chainsaws. They're easier to change and maintain, the machines are more compact and you can go for a bigger diameter machine.
I don't see how chains and bars can be easier to maintain?
I've always gone for TT circular saw blades on my processors.
I've never had a moments trouble with them, cut fast and smooth and stay sharp for years, IME.
Admittedly I've no experience of any processors running chains, but have plenty of experience of chains and bars, they do require a fair bit of maintenance, IME.
  • Replies 34
There's pros and cons to both, it's just person preference I think.
We originally changed from circular saws because the chainsaws go bigger. We're up to a Tajfun 480 now and even if we liked circular saws it would be hard to find a reasonably priced one that size. Also when you chipped teeth it was alot more work to replace a circular saw and we had to take them away to be sharpened which meant having another expensive spare around.
We sharpen every 30 cube and dress the bar every 60 on average, that's not too bad on hardwood. They last a lot longer than a normal chainsaw because you only ever crosscut.
I have 10 chains on rotation and just keep changing them so downtime is only 10 minutes plus the odd re tensioning. There's also less dust with a chainsaw.
For arb waste you can't go wrong with a chainsaw and axe or hydraulic log splitter, and if your not doing a great volume then don't over complicate things by getting expensive machinery as all it will do is produce what u need then sit around for a while and obviously with more machinery comes more expense and more trouble with it breaking down or getting pinched!!
hi their it seems if you are cutting up arb wood for firewood like the the one on you tube i would buy a kiln and burn it would be more profit in it
Or sell it to a man with a kiln
