My understanding of 'moisture content' follows Quickthorns 'dry' basis. Therefore, if say, a lump of fresh cut willow has a moisture content of 120%, then the weight of water is 1.2 X the weight of the wood in the completely dry piece.
If air drying reduces the moisture content to 20% then the piece will weigh just 54.5% of it's original weight.
  • Replies 56
I reckon you got it right earlier, if a lump of wood is 32% water then 68% isn't water (ie pure wood) therefore 68% x 8kg = 5.44kg is pure dry wood. To find out its weight witha mc of 11%, multiply 5.44kg by 111%, = 6.038kg
No thats wrong again.
It's easier to think of it as weight. so
If the original dry log weighs 1000 grams
The you add 32% moisture
that makes the log 1320g
But that doesn't mean 68% is the log,
because 68% of 1320 is 897g
whereas 68% of the dry log is 680g
I can't even think straight now, someone sort it out :confused1:
That doesn't work because the 11% is of the weight of the dry wood rather than being 11% of the wood-including-water.
If you want to get the weight where the water is 32% of the wood-including-water weight you have to calculate a multiplier - in this case 100/(100-32) = 100/68 = 1.47 .
So take your 1000g dry log and multiply it by 1.47 = 1470g when it has 32% ( by weight ) water. Double check by doing 68% of 1470 = 1000 .
If you want to calculate by the other method, for example when the log is described as having 32% water but it is not by weight but in relation to the wood weight (so you could have say 140% for example) then the calculation is;
Wet Weight = Dry Weight + (0.32 x Dry Weight)
Wet Weight = Dry Weight x 1.32
Wet Weight = 1000g x 1.32 = 1320g
Converting from a wet weight with 32% to 11% using the " not % by weight" (NBW) method;
Wet weight =1320g ( at 32% NBW )
Dry weight = Wet Weight / ( 1 + 0.32 ) = 1000g *32% converted to 0.32 for clarity.
Add 11% (NBW);
Wet Weight at 11% = 1000g x 1.11 = 1110g .
To try this with a 150% ( NBW) water content, ie more water than wood;
(Assume dry weight is 1000g as above, water weight will be 1500g)
Wet Weight at 150% = 2500g
Dry Weight = Wet Weight / ( 1 + 1.5) *150% converted to 1.5 for clarity, it would be 150 / 100 but I can't do the graphics.
Dry Weight = 2500 / 2.5 = 1000g.
So for the original equation with 8000g at 32% (NBW) to 11% (NBW);
Dry Weight = 8000g / (1 + 0.32)
Dry Weight = 6060g
Add 11% = 6060 x 1.11 = 6727g
Probably :001_smile:
