compression test questions
Richard Thompson
I have a comp test kit just turned up in the post all well and good and I understand that I will need to seal the exhaust and carb sides of the cylinder. So my question is what do you use for the temporary seals? ,
I have some tyre inner tube that I can cut for gaskets but do you place a profiled blank (steel, rigid plastic or alu ) over or just place the carb back on and screwed down tight?
I'd like to see as much as possible and reduce the amount of clutter so I can see any possible leaks.
I'm not really enthusiastic about grinding dozens of gaskets/plates for every two stroke engine I see if not needed
