Sugihara chainsawbars website....
Rob D
This is not a new site but haven't really got round to promoting it much :blushing: Still unfinished but now starting to take shape.
All bars listed here are the actual physical pictures of every single bar.
Few people have asked - why have a new site? why not just add the bars to chainsawbars.co.uk and have done with it?
Main reason is chainsawbars.co.uk was designed to work with standard set ups ie. if your MS261 comes with a .325 .063 drive sprocket that's what the bar and chain selectors throw up.
Sugihara has all bar options - and now chains to match. Soon we are hoping to add the drive sprockets which will be tailored to match the saw and bar combo ie. you want to try a 3/8 lo pro set up on your MS261 - when we add sprockets you should be able to do this from one page and it should be easy and straightforward.
Anyways - free shipping on the www.sugiharabarsuk.co.uk website for a while to get people trying it!
And any comments or feedback welcomed :biggrin:
:001_smile:
Edited by Steve Bullman
  • Replies 24
Nice one Rob. I'll be ordering a 15" Sugi bar (not long after the Piranha chain has kicked the Husky bar into touch)!
While I remember thought I'd give a bit of feedback after using the Woodchuck Dual:
- It's not just great for rolling big trunks but also brilliant for rolling hung up trees.
- I found the neoprene handle came unstuck after a while so they need to use a stronger glue for that.
- They missed a trick!.... the removable pin should be designed to be removed and replaced with a felling lever pin.
Think that's all for now.
cheers, steve
cheers, steve
Yep that handle does need better glue...
As for the felling lever attachment I mentioned that to them a while ago and i think they are finally making one now!
:001_smile:
:001_smile:
That's great. Did you fall over when the handle came off?...the first time it happened I landed in a ditch. :laugh1:
cheers, steve
