  • Replies 36
As for comparison to the 115, the 115 is lighter and has more power.
I looked a lot on German forums before buying though, and everyone that's used or owns both said they'd take the 5105, so maybe the power rating is more of a paper exercise? (or maybe the figures from 20years ago were measured differently?)
The 115i isn't and wasn't rated at more power than the 5105, it was/is slightly less, as long as the ratings were in the same kind of hp (DIN hp = metric hp). This is brake hp that is measured.
If you have seen the 115 rated in the ol' calculated SAE hp, the numbers would be higher though....:biggrin:
To me the 5105 is too heavy and ungainly for a 50cc saw, so it isn't really an option - but not everyone agree or care.
The inboard clutch design has a lot to do with the ungainliness/bad handling in the woods.
Edited by SawTroll
I'd love to know this summer thing with the 550. Hot or cold mine starts just fine . If the saw has cooled down a bit 2 squirts on the primer bulb and its away. I run mine on a 13 inch bar and I got to say its just a brilliant saw 2 years faultless running and its going in the box with me when I stuffle off this mortal coil
Those who have cared to look in the user manual rarely have any problems with them.
I agree the old SAE and Din HP rating where exaggerated
And your own conclusions should be drawn from use of the said saw
The 115 again is a different saw and from the 5105 as you know the 5105 is much higher rpm , but the 115 has a lower RPM max power and has gains lower down but the 5105 has gains higher so coupled with newer styling works :thumbup:
And again the older style of the 115 works for some but not all iam one who has had one from the start
It's like the predesesor to the ps-420 the 401 , 410 Totaly different but
It works a great seller since its launch all those years ago :thumbup:
I'd like to try an echo, but If i needed a new 50cc saw I'd port a 346. My ported 254 takes loads of pulls to start from cold but starts with one pull every time once warm. It will out cut a 550 and has a great pick up too, and this is a 20+year old saw, the 346 has side chain tensioning and a better chain brake, hence that would be my choice.
