How long should Shock absorbers Last
Lillywhite Timber
Hi everyone , is it possible that a new set of rear Monroe shocks could be gone in around 7-8 months ?. Over the last couple of weeks my old td5 disco has been feeling a bit spongy , when you brake hard with the trailer behind it dips discernibly more than it used to .
I got a pair of Monroe (described as high quality and almost the most expensive available , at the motor factors) fitted around last July .
It went through the DOE with no mention of any suspension problems last Tuesday but theres definitely something wrong there , could the coil springs be gone ? , it does average miles but almost full time trailer work .
Our roads down here in west cork are so badly rotten and holed that very few shocks last more than a year now especially on the defender with ifor williams trailer behind. They have to work damned hard.
Britpart ones will only be about 8- 10 months. You never really notice they've failed til you put new ones on , but handling progressively becomes more erratic. Got terrafirma on at the moment , doing okay but rear springs are going now.
The roads in parts of Kildare are as bad ...
