I really rate this company, above all other rope manufacturers. I made a short video for them from yesterdays job. Use HD setting. Thanks.
Β
  • Replies 20
Excellent vid Reg.
Β
I use Yale Polydine 16mm for most of my heavier rigging.
Β
Great rope and one you can trust.
Β
Alright Rich. Yeah its brilliant stuff. I recall reading the stats on it once and the the cycles to failure rate via shock-loading was off the scale compared to the competition. Very reassuring stuff to use.
I have had mine a few years, but IIRC the MBS was not far off the 19mm Double Esterlon.
Β
Only difference is I can still use the Grey Impact block as opposed to upgrading the hardware to suit 19mm.
Β
You might even recognise the device at the bottom mate... haha.
Β
Edit: Oops there is a crab on that bottom pic. Hope the rigging police don't spot it. ;)
  • Β
Arbtalk.co.uk is a hub for the arboriculture industry in the UK. Β
If you're just starting out and you need business, equipment, tech or training support you're in the right place. Β If you've done it, made it, got a van load of oily t-shirts and have decided to give something back by sharing your knowledge or wisdom,Β Β then you're welcome too.
Γ—
Γ—
