  • Replies 345
Not if the split tether and the HC are on the same side of the biner? And then if you use a neck tie that could go on the other end of same biner? I'm just thinking outload here, I know nothin! (no g)
Kits in the post. Here tomorrow. I'm on holibobs for a week so wont get to try it for while............
I have the split tether from Treekit and the elastic neck strap thingy from them as well. One issue is I cant use either of the holes on the hitch climber to clip my neck strap, just have to clip to one of the legs on the tether. Works but doesn't look nice.
Don't understand why you can't? The small dmm on mine clips straight on although my neck tether is home made but very similar in design.
I clip my neck tether in the top hole ,cord and wrench bottom and haas on the middle and this system is easiest after lots of experimenting for myself to use .
Edited by MattyF
Hi,
I clip it all on the same carabiner on the bottom hole of the hitch climber so the other two holes are blocked by the tether. Distance is quite good between the top of the vt and the bottom of the rope wrench so I never bothered moving it around. I will have a go next week at running the tether off the top ring. cheers
I guess having the tether on top hole of HC might add flex in the sytem? Give it a try. Im home now and my stuff was delivered to the butchers at the end of my road (standard for UPS) so will go and get it first thing in morning. Not working for another week though.
