when I was putting our Vermeer 252 away today I noticed that half of the exhaust was glowing bright red.
any ideas? I was thinking along the lines of a broken exhaust valve on one side am I on the right track
thanks
Possible the baffle has collapsed and is partially blocking the exhaust gasses leaving the first part of the exhaust thus retaining too much heat.
If a valve had failed, the engine would be pretty sluggish and wouldn't raise the temperature.
Mine does it too, but not only on one side. It has to be quite dark to see this and the machine should have had a hard run before. Never turned it off that hot.
Would definitely check the plugs just to be sure.
its never done it before and we have used it when its almost dark.
It hadn't been used had when it started to glow, I had only had it running for 2 mins when driving it into the shed.
I took the spark plugs out today and the one on the glowing side is the grey one and the black one is from the good side
any more ideas, as I haven't taken the exhaust off yet
